1 year agoNot applicable
Problem calculating with decimal numbers
I have a table in which I have decimal numbers as seen below: As you can see it is formatted as decimal number. While creating a measure I`m trying to calculate & count rows where the values ...
- Anonymous1 year ago
ok, I found a solution. Had to change my regional settings on my laptop from English (USA) to English (Europe). For some reason this was messing up the whole calculation
rohit1991
1 year agoHi Anonymous
Could you please try below Step :
1.Change the column’s data type to the correct format >> Decimal Number
2. Create Calculated column:
Flag = IF('Sample Data'[Number] > 0.9, 1, 0)
3. You can create measure as well. It gives you aggregate outcome:
TEMP =
CALCULATE(
COUNTROWS('Sample Data'),
