4 years agoProblem Calculating Total Average
Very good to all, I have a problem when calculating a total average based on two averages already calculated with filters since these have negative values and in the filters I eliminate the negative...
4 years agoSyndicate_Admin , this might be because of row context used
you can avg have using the column in visual
averages(values(Table[column]), [measure] )
4 years agoIs there a way for me to be able to use IF with an average so that I only take into account the largest numbers or giuales to 0 of a column?
