JR_Lee's avatar
JR_Lee
4 years ago
Power Query transformation help
I'm struggling to transform the following data:
so it looks something like the below for each salesperson and each month:
this is where i've got to but i cant seem to isolate the month names:
Attached xlsx link is here
  • Hi JR_Lee ,
    1) add a column with the following syntax: "if [Column2] = "Coke[PG 29]" then [Column1] else null
    2) Check that new column and fill down values. This will returne a column with the repective months in rows.
  • ImkeF's avatar
    ImkeF
    Hi JR_Lee ,
    • JR_Lee's avatar
      JR_Lee
      Hi ImkeF
      Not sure if I have misundestood but when I add the column I get the following (which inclueds the salesperson name)
  • ImkeF's avatar
    ImkeF
    Hi JR_Lee ,
    you must do that before the unpivoting.
    Either before or after the Promoted Headers step:
    • JR_Lee's avatar
      JR_Lee
      amitchandakafter unpivoting all product columns how can i deal with the following:
      • amitchandak's avatar
        JR_Lee , I think this requires a little bit of clean-up outside power bi, having a month on a column.
        But check with M expert.
        ImkeF , any suggestion for this
