Power Query reference later added column
- 7 years ago
Just want to follow up on my previous post, rather than add ton of steps and still can't achieve the goal, at the end I just wrote a short python scripts using for loop and while loop then run it in Power Query Editor to add all columns I want.
Let's see how this goes. I will attach the pbix file below since this is on done in Power Query. But here's what I did:
- Added an index column starting at 0
- Added a new column that will take the max of SOC starting from index 0 (row 1) till the current rows index, which will be 1 less than the current actual row #
if [Index] = 0 then [Array SOC] else List.Max( List.Range(#"Added Index"[Array SOC],0,[Index]),1)
- Added a column for new max if the current soc > max till current row give a 1, else a zero. Unless the index is 0 ( which would be the first row) and then by default that is the max
- added a column for deep cycle if the max til the current row > current array soc
- Removed the index column and Max till current row columns. Dont need to delete them but no sense in keeping them if they arent used elsewhere
File:
Hi Nick, one more thing to address, the current solution can't fully achieve the goal since Current Max is also determined by Deep Cycle: if there is a deep cycle = 1 in previous row, the current max should recount, please see my first screen shot.
Deep Cycle is 1 when (Current Max - SOC) > 70. so basically as this achieved, the Current Max should reset.
Thanks again,
Jiaming
- JeremyLeee7 years ago
For example:
The first apperance of Deep Cycle = 1 is correct, but afterwards Max Till Current Row should be reset to value of SOC, so that there won't be 1 all the way to the end
Wasn't 100% clear to me, but here's what I got.
- Added a TRUE/FALSE column if the Max till Current Row - Current SOC > 0
- Added another column using List.Range and the Index column to get the previous column TRUE FALSE
- New Column for DeepCycle which looks for TRUE in the 1st column we added and then False in the second column
- New column that if Deep Cycle = 1 then give that Rows SOC value, otherwise null.
- Then filled down that column so the value of the SOC column when Deep Cycle was 1 is the value in the rows below it and not null
Also had to account if the index was 0 (since that was the 1st row)
Here's the final table. Made some changes to the Array SOC column so I could see if it was working like I expected. You wouldn't need all these columns and could really compress all these steps into just a few, or even better a function. But left them all there so you could see
PBIX file:
https://1drv.ms/u/s!Amqd8ArUSwDS0ywHNzHBP1ao--Eu
AnonymousHi Nick,
Thanks for your response, the idea is "Max till Current Row" should be reset to current SOC once there's a deep cycle achieved.
In your solution, it works since row 7 (SOC = 800) is bigger than row 2 (SOC = 700), but if I change the value of row 7 to 600, the deep cycle would not be detected.
There should be a deep cycle = 1 in row 8 since 600-66.17>70.
Thanks again.
