Power Query reference later added column
- 7 years ago
Just want to follow up on my previous post, rather than add ton of steps and still can't achieve the goal, at the end I just wrote a short python scripts using for loop and while loop then run it in Power Query Editor to add all columns I want.
Not entirely clear on what makes a new max. Any chance you can load some more data that shows exactly what you are looking to accomplish? This can more than likely be done in Powe Query
- JeremyLeee7 years ago
Hi Nick,
Thanks for your quick response, for clarificaiton:
A New Max is 1 when current SOC is larger than the previous Current Max;
A Deep Cycle is 1 when Current Max is larger than current SOC.
Jeremy
Let's see how this goes. I will attach the pbix file below since this is on done in Power Query. But here's what I did:
- Added an index column starting at 0
- Added a new column that will take the max of SOC starting from index 0 (row 1) till the current rows index, which will be 1 less than the current actual row #
if [Index] = 0 then [Array SOC] else List.Max( List.Range(#"Added Index"[Array SOC],0,[Index]),1)
- Added a column for new max if the current soc > max till current row give a 1, else a zero. Unless the index is 0 ( which would be the first row) and then by default that is the max
- added a column for deep cycle if the max til the current row > current array soc
- Removed the index column and Max till current row columns. Dont need to delete them but no sense in keeping them if they arent used elsewhere
File:
Great, thanks a lot.
Jeremy
