Power Query Pivot/Unpivot Columns Help
- Anonymous3 years ago
Hi Russty99 ,
Please try:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("ldBLCoAwDATQq0jXQjtTm6qn0J0g3v8apvWDggsDhZSQx8Csq4NrHQPpoa9rwJEcIcc2engG/c/NMtVLt7V/zXQaICcDK1HUGY1RxYAyGKOizs4YVQyS5Mr4xVK4WPTsHwWKwdwF9tnC3gX+jzouA4xRtQxjVDWSlW07", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, #"Completion time" = _t, #"Please input indicative prject completion date" = _t, Attribute = _t, Value = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"ID", Int64.Type}, {"Completion time", type datetime}, {"Please input indicative prject completion date", type date}, {"Attribute", type text}, {"Value", Int64.Type}}), #"Pivoted Column" = Table.Pivot(#"Changed Type", List.Distinct(#"Changed Type"[Attribute]), "Attribute", "Value", List.Sum), #"Unpivoted Columns" = Table.UnpivotOtherColumns(#"Pivoted Column", {"ID", "Completion time", "Please input indicative prject completion date", "P XP1", "P XP2", "P XP3"}, "Attribute", "Value"), #"Added Conditional Column" = Table.AddColumn(#"Unpivoted Columns", "Custom", each if [Attribute] = "Q XP1" then [P XP1] else if [Attribute] = "Q XP2" then [P XP2] else if [Attribute] = "Q XP3" then [P XP3] else null), #"Renamed Columns" = Table.RenameColumns(#"Added Conditional Column",{{"Attribute", "Product"}, {"Value", "Quailty"}, {"Custom", "Price"}}), #"Removed Columns" = Table.RemoveColumns(#"Renamed Columns",{"P XP1", "P XP2", "P XP3"}) in #"Removed Columns"Best Regards,
Gao
Community Support TeamIf there is any post helps, then please consider Accept it as the solution to help the other members find it more quickly. If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
How to get your questions answered quickly -- How to provide sample data in the Power BI Forum
Hi Russty99 ,
Please try:
#"Removed Columns"
Gao
