CoffeeTime's avatar
CoffeeTime
6 years ago
Power Query: List.Max dosn't return max value
I extracted a number from a code and converted it to number in column "NewCode". Then, I would like to create a column with the max value of "NewCode".
Then I added a new custom column:
List.Max(#"PreviousAction"[NewCode])
The thing is that the returned value is not the maximum value:
Can someone help me out?
Then I added a new column with the following code:
List.Max(#"Texto Extraído Entre os Delimitadores"[NewCode])
The thing is that the new column return a value that is not the max value:
Can someone help out?
  • Hi CoffeeTime ,
    I made a sample about using list.Max,and it worked fine.
    Be sure that you have changed your column type to "whole number".
    Here is the related .pbix file.
    Kelly
  • az38's avatar
    az38
    Hi CoffeeTime
    it's better to create a DAX calculated column
    Column = MAX(Table[NewCode])
    • CoffeeTime's avatar
      CoffeeTime
      But this will be used to create the table keys. Later, PBI will use it to relate different tables.
      • HotChilli's avatar
        HotChilli
        9 will be returned if the column is a text type so that's the clue.
        Either something has gone wrong with the data type change or the wrong column is used in the List.Max or something else unusual.
        Could you experiment by entering your own sample number column e.g. 2, 3,5 then add a column using similar code to the sample you posted and prove that works ok.
    • Gareth123's avatar
      Gareth123
      Why do you think it is better to use DAX?
  • v-kelly-msft's avatar
    v-kelly-msft
    Hi CoffeeTime ,
    Kelly
