[Power Query] How to fill missing data from above rows based on condition same Date and Same ID
Hello Community,
I have query from SQL server that collecting log from gps the data will update every minute.
the problem is on column D_Name (Driver Name) some rows data are blanks and i would like to fill data ref from earlier rows
based on same Truck ID and Same Date (Due to Driver might change from day to day on the same truck)
how to fill the correct driver name by Power Query Editor
here are sample file
example photo :
Please Advice
JJ
see my video
- Ahmedx
post this file too
C:\Users\008098\Desktop\SAMPLE.xlsx
- AnonymousNot applicable
Ahmedx
here is the link to excel file
Excel File
- Ahmedx
look at the screenshot and tell me what should be in the D_NAME column?
- Ahmedx
pls try this
let Source = Excel.Workbook(File.Contents("C:\Users\User\Desktop\SAMPLE.xlsx"), null, true), Sheet3_Sheet = Source{[Item="Sheet3",Kind="Sheet"]}[Data], #"Promoted Headers" = Table.PromoteHeaders(Sheet3_Sheet, [PromoteAllScalars=true]), #"Changed Type" = Table.TransformColumnTypes(#"Promoted Headers",{{"V_ID", Int64.Type}, {"V_LICENSE_NO", type text}, {"VLCTL_SMARTCARD_D_CODE", Int64.Type}, {"D_NAME", type text}, {"VLCTL_GPS_DATE", type date}, {"time", type time}, {"VLCTL_ID", Int64.Type}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"V_ID", "VLCTL_GPS_DATE"}, {{"Count", (x) => Table.FillDown( Table.TransformColumns(x,{"D_NAME",(y)=> if y ="" then null else y}), {"D_NAME"}) }}), #"Removed Other Columns" = Table.SelectColumns(#"Grouped Rows",{"Count"}), #"Expanded Count" = Table.ExpandTableColumn(#"Removed Other Columns", "Count", {"V_ID", "V_LICENSE_NO", "VLCTL_SMARTCARD_D_CODE", "D_NAME", "VLCTL_GPS_DATE", "time", "VLCTL_ID"}, {"V_ID", "V_LICENSE_NO", "VLCTL_SMARTCARD_D_CODE", "D_NAME", "VLCTL_GPS_DATE", "time", "VLCTL_ID"}) in #"Expanded Count"- AnonymousNot applicable
Ahmedx ,
The result is correct. Thank you very much. but I dot know How to apply with the actual file. due to it work with advance editor and i dont have exp. on this. Would you mind checking another(actual) file and how to solve the same problem. Thank you in advance.
Sample 2 flie.Sample2
JJ- Ahmedx
see my video
