Power query help
Am looking to create a column in power query editor that will take the monch a order was invoiced then based in the number of months that it needs to be invoiced for will give me the dates. For example;
for an order invoiced on 23/04/2019 and the number of months being 3 the new column should give me 3 months worth of dates for example 23/05/2019 23/06/2019 23/07/2019. Below is a screenshot of the data i am trying to create this with. Any help will be gratefully appreciated
Example table
Calculated column
Expand to new rows
Expanded tableNew calculated columnResult
- tex628
https://docs.microsoft.com/en-us/powerquery-m/list-dates
Create a new column with your month column as count and month as duration. Then expand into new rows.- AnonymousNot applicable
tex628 thank you so much for the response so would it look like this
List.Dates([DateInvoiced],[Months], [Months] )
thank you
- tex628
Nevermind that, apparently its not that simple.
It appear that list.dates cant use month as increment which leaves us with a more complicated solution.
Use List.Numbers to create a record for each month. So you would do something along the lines of:List.Numbers( 0 , [Month] )
https://docs.microsoft.com/en-us/powerquery-m/list-numbers
When the list is expanded you should end up with 1 record representing each month. 1, 2, 3, 4, 5 etc.
Now you want to create a new column using:Date.AddMonths( [DateInvoiced] , [New column that you just made] )
https://docs.microsoft.com/en-us/powerquery-m/date-addmonths
This should give you the desired result! Sorry for the missdirect in the beginning, hope it works out.
Br,
J
