Nooby's avatar
Nooby
6 years ago
Power Query: Fetching a column values from another column
Hello everyone,
I can do this on sql very easy but I have to do it on power bi power query editor with M.
(not DAX)
There is a column with the values:
TABLE1.CODE_COLUMN
XXYYZZTT
PPRRQQSS
And there is another column in another table
TABLE2.DIRTY_DATA
123123XXYYZZTT123123123
XXYYZZTT44223xxxxxfdwe
dadfewrerXXYYZZTT987
asdf324aerq
daf33421adf
1PPRRQQSSr2d2
I have to search the first column values one by one and when I find the value, I have to extract the first value before it, itself and following 3 characters with it.
The new 3 columns would be:
TABLE2.FETCH1TABLE2.FETCH2TABLE2.FETCH3
3XXYYZZTT123
tXXYYZZTT442
rXXYYZZTT987
nullnullnull
nullnullnull
1PPRRQQSSr2d
I'm not able to do it with standard buttons:
  • ImkeF's avatar
    ImkeF
    6 years ago
    Hi
    I've split up the process into (hopefully) digestible steps (please also check attached file):
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("NYo7DoAgEETvQm3DLol6C34FQihIFnqxwOOLKJPXzMwLgXHAjnPH4b21X+uwuAQ2VyEA8H5TqOVxUaKSW811Ovu2jiNdVBBEyvX8xYIogHd/dC6l1koZU4GAxfgA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [Column1 = _t]),
        ListOfFoundCodes = Table.AddColumn(#"Changed Type", "PositionOfText", each List.Transform(Table1_Code_Column[Column1], (x) => Text.PositionOf([Column1], x))),
        IndexOfCode = Table.AddColumn(ListOfFoundCodes, "IndexFoundCode", each List.PositionOfAny([PositionOfText], {0..1000})),
        PositionWithinDirtyData = Table.AddColumn(IndexOfCode, "PositionOfTextWhereFound", each List.Max([PositionOfText])),
        Fetch1 = Table.AddColumn(PositionWithinDirtyData, "Fetch1", each try Text.Range([Column1],[PositionOfTextWhereFound]-1, 1) otherwise null),
        Fetch2 = Table.AddColumn(Fetch1, "Fetch2", each if [IndexFoundCode] = -1 then null  else Table1_Code_Column{[IndexFoundCode]}[Column1]),
        Fetch3 = Table.AddColumn(Fetch2, "Fetch3", each if [IndexFoundCode] = -1 then null else Text.Range([Column1],[PositionOfTextWhereFound] + Text.Length([Fetch2]),3))
        Fetch3
    • ImkeF's avatar
      ImkeF
      Hi
          Fetch3
      • Nooby's avatar
        Nooby
        Dear ImkeF ,
        it works like a charm, thank you very much.
        I see my sql knowledge doesn't help at all, it seems so complicated that I couldn't solve it on my own.
        I do everything on sql and trying to get familiar with Power BI lately. What source would you offer to be able to write this code of yours, 'cause the ones I studied didn't help at all.
        and thank you amitchandak!
