Austen229022's avatar
Austen229022
1 year ago
Power Query Duration between Dates excluding Weekends Wont Load
I am using a database to import rows of details into my dashboard, with a calculation of working days between the Received and the Issued dates. There are around 120k rows, and only have Case ID, Received Date, Issued Date and 2 other columns in the table.
A Calendar list has been created taking out all the working days so it is just weekends and public holidays.
From this, I have created a query as follows:
(StartDate as date, EndDate as date, HolidayList as list) as number=>
    DateList=List.Dates(StartDate,Number.From(EndDate-StartDate)+1,#duration(1,0,0,0)),
    //create series of Dates
    RemoveHolidays=List.RemoveItems(DateList, HolidayList),
    //remove holidays
    Countdays=List.Count(RemoveHolidays)
    //count days
  Countdays
When I then add this into my table as below, it takes literal hours to load and I have to close the program through the Task Manager.
Can anyone help with this issue so that it will actually load?
    1 year ago
    Hi Austen229022,
    I have reproduced your scenario in Power BI as per your requirements. Please find attached.pbix file for your reference.
    If this response helps, consider marking it as “Accept as solution” and giving a “kudos” to assist other community members.
  • Ashish_Excel's avatar
    Ashish_Excel
    Icon for Solution Supplier rankSolution Supplier
    It may be better to do this in DAX as a calculated column formula.  Share some data to work with and show the expected result.  Also share the list of public holidays.
  • Hi Austen229022,
    Instead of doing the step in Power Query, can you try doing with DAX?
    Step-1: Create a Date table with excluding weekends and holidays
    Step-2: Use the above Date table to join with your table
    Best regards,
    Maruthi
        Hi Austen229022,
    Hi Austen229022
    Hi Austen229022
