yossifisch
Advocate I
8 years agoPower Query decimal precision problem - does not get to 0 when negative values equal positive values
I have source data with over a million rows with a dollar amount in each. A large percentage of those amounts cancel each other out, so there is the same amount in negative value as in positive. The ...
- Anonymous8 years ago
Hi yossifisch,
I got the feedback from power query team.
They suggest you to use precision argument with List.Sum, it can fix this issue.
Sample:
List.Sum([amount], Precision.Decimal)
Full query:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjJV0lEyNNQzMFGK1YFyddH4pnqmRkiyqFwgzxCfJF6dxuQZi829xvilCXknFgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [order = _t, amount = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"order", Int64.Type}, {"amount", type number}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"order"}, {{"Sum", each List.Sum([amount], Precision.Decimal)}}) in #"Grouped Rows"Regards,
Xiaoxin Sheng
yossifisch
Advocate I
8 years agoThanks Anonymous, this works but what if I don't want to summarize using groups but rather an Excel Pivot Table (as in my original post), is there a way to set the Pivot Table's behavior to use Precision.Decimal?
8 years agoNot applicable
HI yossifisch,
I'm not so familiar with pivot table, maybe you can post to power pivot related forum to get further support.
Xiaoxin Sheng
