Power Query decimal precision problem - does not get to 0 when negative values equal positive values
- Anonymous8 years ago
Hi yossifisch,
I got the feedback from power query team.
They suggest you to use precision argument with List.Sum, it can fix this issue.
Sample:
List.Sum([amount], Precision.Decimal)
Full query:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjJV0lEyNNQzMFGK1YFyddH4pnqmRkiyqFwgzxCfJF6dxuQZi829xvilCXknFgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [order = _t, amount = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"order", Int64.Type}, {"amount", type number}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"order"}, {{"Sum", each List.Sum([amount], Precision.Decimal)}}) in #"Grouped Rows"Regards,
Xiaoxin Sheng
HI yossifisch,
If you not care about value after huge amount of decimal places, I'd like to suggest you add custom column with Number.Round function to round these value.
Then calculate with 'round up' values and they will get to 0 when negative values equal positive.
Xiaoxin Sheng
Anonymous That doesn't work (and BTW I think setting to Currency type already takes care of rounding).
Sample data:
| order | amount |
| 25 | 11.04 |
| 25 | -11.04 |
| 25 | 5.52 |
| 25 | -5.52 |
| 25 | 5.51 |
| 25 | -5.52 |
| 25 | 5.52 |
| 25 | -5.52 |
| 25 | 5.53 |
| 25 | -5.52 |
| 25 | 5.51 |
| 25 | -5.52 |
| 25 | 11.04 |
| 25 | -11.03 |
| 25 | 11.04 |
| 25 | -11.04 |
| 25 | 5.52 |
| 25 | -5.52 |
Sample Power Query code:
Source = Csv.Document(File.Contents("C:\Users\ABC\Documents\Book1.csv"),[Delimiter=",", Columns=2, Encoding=1252, QuoteStyle=QuoteStyle.None]),
#"Promoted Headers" = Table.PromoteHeaders(Source, [PromoteAllScalars=true]),
#"Changed Type" = Table.TransformColumnTypes(#"Promoted Headers",{{"order", type text}, {"amount", type number}}),
#"Added Custom" = Table.AddColumn(#"Changed Type", "Custom", each Number.Round([amount], 2)),
#"Grouped Rows" = Table.Group(#"Added Custom", {"order"}, {{"Sum", each List.Sum([Custom]), type number}})
#"Grouped Rows"Result data:
| order | Sum |
| 25 | 1.78E-15 |
Again, this is a tiny number that is not noticed when summarized in a pivot table with formattinge set to currency but in my large data set this resulted in a $4 discrepancy.
- Anonymous8 years agoNot applicable
Hi yossifisch,
Sample:
Full query:
Xiaoxin Sheng
- yossifisch8 years agoAdvocate I
Thanks Anonymous, this works but what if I don't want to summarize using groups but rather an Excel Pivot Table (as in my original post), is there a way to set the Pivot Table's behavior to use Precision.Decimal?
HI yossifisch,
I'm not so familiar with pivot table, maybe you can post to power pivot related forum to get further support.
Xiaoxin Sheng
HI yossifisch,
I reproduce your issue, it seems like list has calculate wrong result when it deal with values which has different symbol(negative /positive) and same absolute.
I Will contact to power bi team to confirm this issue and update here if any feedback.
Regards,Xiaoxin Sheng
