numersoz's avatar
numersoz
6 years ago
Power Query Conditional Column with NULL Values
I need to clean up sensor data. I know that if the sensor data is a negative number or below a certain treshhold, it should be zero.
I do this with a conditional column, if below the treshhold I set them to zero. But there are also null values. So I do an if elsestatement for null = null.
But I can error for the rows which contain null. I have to replace errors and make them null again. Is there an another approch to this so I don't get errors?
  • camargos88's avatar
    camargos88
    Hi numersoz ,
    Try this:
    If you start comparing anything with null you get errors.
    • numersoz's avatar
      numersoz
      Thank you this did solve the problem. I am not sure why the otherway didn't work.
        camargos88
        numersoz ,
        That's because if you compare null with any value, you are gonna get error.
        So start checking the null values.
  • numersoz what is the data type of this column? Is it a number? Change it to the number and then apply the conditional logic.
    I would ❤ Kudos if my solution helped. 👉 If you can spend time posting the question, you can also make efforts to give Kudos whoever helped to solve your problem. It is a token of appreciation!
    • numersoz's avatar
      numersoz
      Above post solve the problem but not sure why the otherway didn't work.
      The data type was a decimal number.
