Power KPI Matrix Help
Hello - I am trying to use the Power KPI Matrix (could be a VERY valuable tool for our teams) but it seems to be very unfriendly to create. Maybe I am just unaware how to use it. I have searched the Power BI site as well as Google to try to find tutorials on how to use it but there is not much out there that is useful. I was wondering if someone could help me. Do you need to create a separate table in order to use this? I have measure tables that I have created to give me the metrics for all my KPI's which I can add to the matrix just fine, but when I try to do a KPI status and comparison values nothing shows up. I get no icons, no comparison value, nothing.
Can anyone help me with how to use this visual?
Thank You!
Ryan
- Rfranca
Resolver IV
hi, Anonymous
Power KPI Microsoft Corporation
A powerful KPI Indicator with multi-line chart and labels for current date, value and variances.The Power KPI visual is for presenting a key performance indicator (KPI) along with a variety of supporting information, including:
- Title, Subtitle
- Current date and KPI status (value, indicator symbol, variance)
- Line chart with KPI trend, forecast line, and other comparison lines, as well as tooltips
Please try and test using it. And please mark the right reply as answer if your issue has been resolved, otherwise, please feel free to ask if you have any other issue.
Rfranca- AnonymousNot applicable
Hey Rfranca I am looking to use the Power KPI MATRIX. I have used the Power KPI before and it is nice, but I want to use the Matrix as a scorecard and then it provides the ability to see the Power KPI line graph for each specific KPI when clicked on.
I am having issues creating the Matrix as I am not able to get KPI Statuses or Comp Values to show.
