Power BI visualization issue
Ok, it looks like your original question still stands and you haven't followed the previous answers given by myself or the other dude. So you are probably at the start of your powerbi journey.
For long term answers : read this https://docs.microsoft.com/en-us/power-bi/service-aggregates i know it says powerbi service but it applies to desktop too
Short term : You think that you don't want to aggregate your number of defects but actually you do. And you want to use SUM. Go back to your visualisation , you have week# on the axis and Defects in values. Go to the Values section, click on the small triangle next to Defects. We think that a tick will show next to Count but you really want to tick Sum. So tick Sum and your visualisation should show what you want. If it doesn't, there may be an issue with the data type used for defects so attach your pbix and i'll look at it.
I have tried the previous replies.. Sum doesn't cut it either because it sums every defect and outputs the total # of defects for the year for every week number.
- abrown8 years agoRegular Visitor
Also "do not summarize" is not listed as an option. I updated the query to change the data type to text and the option was still not available.
- HotChilli8 years ago
I can't get the full situation from the picture you just posted because the visualisation wasn't selected at the time you took the screenshot.
But it does look like you don't have the correct datatypes on your fields in the PER WEEK table.
Link your pbix and i'll look at it
