metecakmak
4 years agoNew Member
Power bi sql connection
Hello, I'm new on Power bi. I have a code on SQL server and I want to connect Power bi to visualize my codes but my SQL server on a virtual machine (VMware). When I clicked get-data on power bi it r...
parry2k
4 years agometecakmak can you connect to SQL server thru any other tools like SSMS from your machine? If yes, use the same credentials, connection in Power BI.
✨ Follow us on LinkedIn and to our YouTube channel
Learn about conditional formatting at Microsoft Reactor
My latest blog post The Power of Using Calculation Groups with Inactive Relationships (Part 1) (perytus.com) I would ❤ Kudos if my solution helped. 👉 If you can spend time posting the question, you can also make efforts to give Kudos to whoever helped to solve your problem. It is a token of appreciation!
⚡ Visit us at https://perytus.com, your one-stop-shop for Power BI-related projects/training/consultancy.
