6 years agoNot applicable
Power BI Row Level Security Help
I need some help with some Row Level Security DAX formulas in Power BI. I have a list of Customers below and a filter selection. Some users can see all the data, and some users can only see part...
- Anonymous6 years ago
What I ended up doing was using a SWITCH function. I created a new column for each role, then a Measure to Switch between the columns depending on the role.
Measure = SWITCH(SELECTEDVALUE('Table'[Switch]),"A",MAX(Security[Root_Cause_A]),"B",MAX(Security[Root_Cause_B]),MAX(Security[Root Cause]))Here is what the Switch table looks like. I then assign role level secuirty to select a single row in the Switch table.Here is what the table looks like viewing as Customer B. Notice how the Measure field is blank for all Customers except Customer B.
6 years agoAnonymous , see if these can help
https://community.powerbi.com/t5/MBAS-Gallery/Microsoft-Power-BI-Unleash-row-level-security-patterns-in-Power/td-p/712613
https://radacad.com/dynamic-row-level-security-with-organizational-hierarchy-power-bi
