talb
9 years agoNew Member
power bi refresh problem
hi All I have a Power BI Desktop connected to Dynamics CRM Online (using API). I published a Dashboard to the Online Power BI and I can see it. I downloaded the Service App for the Online Power BI,...
v-sihou-msft
9 years ago
Did you use a Mashups between a cloud source and an on-premises source in a single query?
If so, it will fail to refresh in the personal gateway if one of the sources is using OAuth for authentication. It's a known issue. To work around this problem, you need to have a separate query for the cloud source and the on-premises source and use a merge or append query to combine them. For more details, please see: Troubleshooting Power BI Gateway - Personal
Simon Hou
