power bi refresh problem
Did you use a Mashups between a cloud source and an on-premises source in a single query?
If so, it will fail to refresh in the personal gateway if one of the sources is using OAuth for authentication. It's a known issue. To work around this problem, you need to have a separate query for the cloud source and the on-premises source and use a merge or append query to combine them. For more details, please see: Troubleshooting Power BI Gateway - Personal
Simon Hou
Thank you,
my problem is that I am trying to connect the Power BI to an Online Dynamics CRM BUT all my data are on a custome fields. to my understanding, the Online Power BI can only read the OOB fields. to go around this (since I don't think there is a single company that didn't customizaed the system somehow), I opened a Desktop Power BI, connected the Online CRM via API and published the report.
now I want it to refresh automatically on the site without me havign to refresh and republish every day.
is that possible?
do you happen to know a better way to connect the Power BI site to the CRM catching the customized information?
