Power BI Python Script Issue
Hi Romani did you try with import part
import matplotlib.pyplot as plt
check link for other work python in power bi
# 'dataset' holds the input data for this script
# Import the translation library
from textblob import matplotlib.pyplot as plt
# Create a function for translation
def translation(text):
blob = TextBlob(text)
return str(blob.translate(from_lang='ar', to='en'))
# Apply the translation function to the relevant column in the dataset
dataset['translation'] = dataset['Comment'].apply(translation)
after your update the below issue appeared:
DataSource.Error: ADO.NET: Python script error.
<pi> File "C:\Users\romany.fahmy\PythonScriptWrapper_1a152b9c-825d-4fbb-b52c-05213fa30147\PythonScriptWrapper.PY", line 18
SyntaxError: invalid syntax
</pi>
Details:
DataSourceKind=Python
DataSourcePath=Python
Message=Python script error.
</pi>
ErrorCode=-2147467259
ExceptionType=Microsoft.PowerBI.Scripting.Python.Exceptions.PythonScriptRuntimeException
