Power BI Push data using Power Apps
Hi Team
I have a Sql server db as a source and I have created a Power Apps app that has been embedded in Power BI report. Using the Power Apps app user can insert, edit and delete data in Sql server. In the report we have visuals that are based on data from this Sql server db. Once a action is taken using Power Apps data is getting properly updated in the table but we need to refresh the report to update it. Can we have it in real time as soon as you submit a change using Power Apps app i.e you need not hit refresh on Power BI. We also have DAX calculations in this dataset.
- v-frfei-msft
Hi Anonymous ,
Based on my test, it is not possible to meet your requirement currently.You can come up a new idea about that and add your comments there to improve Power BI and make this feature coming sooner.
https://ideas.powerbi.com/forums/265200-power-bi-ideas
- AnonymousNot applicable
Hi Team
Any workaround for this? I am using Direct Query connection with Sql Server.
