Power BI Map Help
Hello!
I am reaching the Power BI delierium stage of knowing the solution is likely really simple (and my error is silly). Please help me regain my sanity.
I have a dataset that basically shows sales (count and amount) at the transaction level across the United States. I want to use the map visual to create the dots (based on amount $) to viusally see where all sales are, and where most money (amount) of sales are going.
I have a Census Tract column, county column, state column, zip code column, and a merged county, state column. When I go to make the map visual - it shows up oddly and all over the globe. I am not sure where I am going wrong currently.
I copied that same dataset and grouped by state and county (county, state) and was able to make a table that summed up the total sales amount by county, state - but the map visual is not working.
What am I doing wrong?
Thanks in advance.
Hi W2SANC ,
- v-venuppu
Hi anilelmastasi ,
Thank you anilelmastasi for the prompt response.
After creating a calculated column as suggested by anilelmastasi as below:
Create a calculated column that clearly identifies each location. Like below formula:
CountyState = [County] & ", " & [State]
- After creating the column, click on it (just select it in the Fields pane).
- Now go to the Modeling tab at the top ribbon.
- In the Modeling tab, look for Data Category, and from the dropdown choose "Place" or "County".
Please find the below screenshot for your reference:
If this post helps, then please consider Accepting as solution to help the other members find it more quickly, don't forget to give a "Kudos" – I’d truly appreciate it!
- anilelmastasi
Hello W2SANC ,
Could you please send a screenshot of error?
What error do you get when you want to creat map visual?
At Data View you can select:
Column Data Category-------------------------------
State State or Province
Zip Code Postal Code
County County- W2SANC
Helper II
See the thread above - I fixed the visual aspect, but still have a few points showing in other countries but when you hover, it still shows locations in US (Ex: Albermarle, Virginia) but shows in South America.
- W2SANC
Helper II
Hello -
I have changed some of the relationship connections on the backend, and that has helped keep it within the US (yay!) - now my only question is - I was hoping to have the map that showed circles (where the larger the circle indicates larger $ deployed in that place). See in the attached photo that I currently have shaded in counties/places, and for my purposes, this isn't the most helpful visual. I also am not 100% what shaded means (darker color saturation = more $?)
- anilelmastasi
Hello W2SANC ,
You are currently using Filled Map. Shading = relative intensity (darker = more $ deployed)
But what you want is Bubble Map. This is the standard “Map” visual, not the “Filled Map.”
You can swith to map with:
In the Visualizations pane, change from “Filled Map” to “Map” (looks like a globe icon 🌐)
In the Fields pane, configure it like this:
Size: $ Deployed (your numerical field)
Set Data Category on the Location column to “Place” or “County”
If this solved your issue, please mark it as the accepted solution. ✅
- W2SANC
Helper II
Thank you! I did that can got the visual results I wanted. BUT, there are still a few dots that show in other counties (see below photo).
I'm not sure how to fix those specific data points. See below. If I hover over those points, it still has labels as County, State in the US (example - Albermarle, Virginia)
