Anonymous's avatar
2 years ago
Power BI Logic Help
I have a set of date columns in a table where i need to showcase the timeline progression based on the order of columns.
Suggest me the logic and the related chart for it.
ex: date 2-date 1 = days ,
date 3- date 2 = days
DatesDataType
Date 1Date Time
Date 2Date Time
Date 3Date Time
Date 4Date Time
    2 years ago
    Hi Anonymous ,Hello PijushRoy ,
    Thank you for your prompt reply.
    Based on my understanding, you want to calculate difference between dates as days.
    Per my test, we can create an index column from 1 in power query for sorting your Date column:
    Then create a measure using the following code to meet your requirement:
    DateDiff = VAR currentIndex = SELECTEDVALUE('Table'[Index])
    VAR currentDate=CALCULATE(SELECTEDVALUE('Table'[Date]),FILTER(ALL('Table'),'Table'[Index]=currentIndex))
    VAR preDate=IF(currentIndex=1,CALCULATE(SELECTEDVALUE('Table'[Date]),FILTER(ALL('Table'),'Table'[Index]=1)),
    CALCULATE(SELECTEDVALUE('Table'[Date]),FILTER(ALL('Table'),'Table'[Index]=currentIndex-1)))
    DATEDIFF(preDate,currentDate,DAY)
    Result for your reference:
    I hope my suggestions give you good ideas, if you have any more questions, please clarify in a follow-up reply.
    Best regards,
    Joyce
  • PijushRoy's avatar
    PijushRoy
    Hi Anonymous
    The requirement is not clear to me.
    Can you explain more, what is your initial data and what is output you are looking for.
    Best regards,
    Joyce
