Heinrich's avatar
Heinrich
Icon for Post Partisan rankPost Partisan
4 years ago
Power BI Filter Pane - Data Field with a variable
Hello
Can I use a variable in the Data Field within the Filter Pane.
I.e.: the Data Field has a variable (see example) and this variable gets the value from another table/page.
Thank you
Heinrich
  • v-zhangti's avatar
    v-zhangti
    Hi, Heinrich
    Can you provide some sample data or simple pbix files? Sensitive information can be removed in advance. What kind of expected results do you expect? You can also show it with pictures.
  • Heinrich's avatar
    Heinrich
    Hello Charlotte
    Hope you are well. As said
    one page with the data called KPI's
    one page with the time called TIME
    The KPI have in the visuals a filter called Duration
    The TIME have a table with a column "time" with the number i.e. 7
    The visuals in KPI with the filter Duration is not expressed as a fixed time but as a variable $time
    which refers to the page TIME and to the table / column "time"
    Is that explanatory
    Heinrich
  • Heinrich's avatar
    Heinrich
    Hello
    Thank you very much.
    I tried to make an example.
    Hope this helps
    Heinrich
