6 years agoNot applicable
Power BI embeded <PowerBIFilter> reference
Hello, I am trying to call a powerBI from Dynamics CRM using the contains operator. I use the following syntax to call a report using the is operator: <PowerBIFilter> { "Filter": "[{\"$schema...
- Anonymous6 years ago
I solve my situation by re-organizing the query at the SQL Server level, by using a view that reproduces the left join I was using in PowerBi with contains.
