Power BI drill through
- Anonymous2 years ago
Hi Anonymous
You can refer to the following solution.
Sample data
1.Create a table
Table 2 = SUMMARIZE('Table',[Sifra artikla])2.Then create a relationship between tables.
3.Create a measure
MEASURE = VAR a = CALCULATETABLE ( VALUES ( 'Table'[Broj fakture] ), 'Table'[Sifra artikla] IN VALUES ( 'Table 2'[Sifra artikla] ), CROSSFILTER ( 'Table 2'[Sifra artikla], 'Table'[Sifra artikla], NONE ) ) RETURN CALCULATE ( COUNTROWS ( 'Table' ), 'Table'[Broj fakture] IN a, CROSSFILTER ( 'Table 2'[Sifra artikla], 'Table'[Sifra artikla], NONE ) )4.Then in the first page put the Sifra artikla field of table2, in the second page put the measure and the Broj fakture , Sifra artika of original table the table visual.
5.Put the Sifra artikla field of table2 to the drill through filter at the second page
Output:
select 100 at the first page
Then drill through.
Best Regards!
Yolo Zhu
Anonymous , On the drill through page disable - Keep all filters and then Add all columns you want to pass the values in Drill through from. Do not keep the one you do not want to pass
Power BI Drill Through - More than one level: https://www.youtube.com/watch?v=hCAAvpppQmk
No, this is not what i want.
You can see my first image, that I have Sifra artika 5892332100 and i have Sifra artika on two Broj fakture.
But my Broj fakture have multiple Sifra artika, you can see on this image :When i click to drill through on my Sifra artkla, I want to eliminate filter from Sifra artikla but keep filter for Broj fakture to show me other Sifra artikla what have on this two Broj fakture.
Hi Anonymous
Sample data
1.Create a table
3.Create a measure
Output:
Then drill through.
Best Regards!
Yolo Zhu
