Brite's avatar
Brite
5 years ago
Power Bi DAX Measure Adding Wrong Help
Hi everyone,
I am stuck on this measure adding the total wrong and am unsure why.
The DAX formula I am using:
Month1_Reject Rate FINAL = IF([Total_Rejected]<2,(calculate([Pay1],'Fail Cancel.Rejected'[ STRIPE_ID]<>Blank())), 0)
  • Hi Brite ,
    In the total section [Total_Rejected] = 84 > 2, then the measure [Month1_Reject Rate FINAL] returns 0. If you want to sum the measure [Month1_Reject Rate FINAL] in the total section, you can try the following formula:
    Total =
    If(
      ISFILTERED(Table[column]),
      [Month1_Reject Rate FINAL],
      sumx( allselect(Table[column]), [Month1_Reject Rate FINAL] )
    If the problem is still not resolved, please provide detailed error information or the expected result you expect. Let me know immediately, looking forward to your reply.
    Winniz
  • v-kkf-msft's avatar
    v-kkf-msft
    Hi Brite ,
    Total =
    If(
    Winniz
