please help in converting SQL query to Power Bi dax function - cal column
Hi Prathyusika ,
Please try the below code:
Time Bucket = SWITCH( TRUE(), [ClosedDate] >= WM_START_DATE && [ClosedDate] <= DATEADD(WM_START_DATE, 90, DAY) && TODAY() >= WM_START_DATE, "90 Days", [ClosedDate] > DATEADD(WM_START_DATE, 90, DAY) && [ClosedDate] <= DATEADD(WM_START_DATE, 180, DAY) && TODAY() >= DATEADD(WM_START_DATE, 90, DAY), "180 Days", [ClosedDate] > DATEADD(WM_START_DATE, 180, DAY) && [ClosedDate] <= DATEADD(WM_START_DATE, 270, DAY) && TODAY() >= DATEADD(WM_START_DATE, 180, DAY), "270 Days", [ClosedDate] > DATEADD(WM_START_DATE, 270, DAY) && [ClosedDate] <= DATEADD(WM_START_DATE, 360, DAY) && TODAY() >= DATEADD(WM_START_DATE, 270, DAY), "360 Days", TRUE(), "Greater than 360 days" )Best Regards,
Ajith Prasath
If this post helps, then please consider Accept it as the solution and give kudos to help the other members find it more quickly.
- AjithPrasath
Resolver II
Hi Prathyusika ,
Ajith Prasath
- grazitti_sapna
Hey, You can achieve this by
Time Bucket =
VAR WM_START_DATE = 'YourTableName'[WM_START_DATE]
VAR ClosedDate = 'YourTableName'[ClosedDate]
VAR Today = TODAY()
IF(
ClosedDate >= WM_START_DATE &&
ClosedDate <= DATEADD(WM_START_DATE, 90, DAY) &&
Today >= WM_START_DATE,
"90 Days",
IF(
ClosedDate > DATEADD(WM_START_DATE, 90, DAY) &&
ClosedDate <= DATEADD(WM_START_DATE, 180, DAY) &&
Today >= DATEADD(WM_START_DATE, 90, DAY),
"180 Days",
IF(
ClosedDate > DATEADD(WM_START_DATE, 180, DAY) &&
ClosedDate <= DATEADD(WM_START_DATE, 270, DAY) &&
Today >= DATEADD(WM_START_DATE, 180, DAY),
"270 Days",
IF(
ClosedDate > DATEADD(WM_START_DATE, 270, DAY) &&
ClosedDate <= DATEADD(WM_START_DATE, 360, DAY) &&
Today >= DATEADD(WM_START_DATE, 270, DAY),
"360 Days",
Thank you
