Need help with Setting Static KPI Target
Is it possible to have KPI used with static GOAL set under Target Goals. Say for example 50% of total requests received should be resolved through IVR which is Team Target set. Any lead will be helpful.
Refer to this https://docs.microsoft.com/en-us/power-bi/visuals/power-bi-visualization-kpi
Then you can define a DAX measure and use that in the goal field.
Example
Goal = .5*[Total Request]
Appreciate with a kudos πHere is my latest blog
https://community.powerbi.com/t5/Community-Blog/Dynamic-Page-Navigation-Based-on-User-Login/ba-p/1097786
- nandukrishnavs
Example
https://community.powerbi.com/t5/Community-Blog/Dynamic-Page-Navigation-Based-on-User-Login/ba-p/1097786 - amitchandak
cpahuja ,
You can use likeNew Measure = 0.5 * calculate(sum(Table[value]),all(Table))
Also, refer:
https://docs.microsoft.com/en-us/power-bi/desktop-what-if
https://docs.microsoft.com/en-us/power-bi/desktop-analytics-pane
