Need help with returning values
- 6 years ago
hi LittlePero
what values do you see in Power Query Editor mode and in Data window in report mode?
do not hesitate to give a kudo to useful posts and mark solutions as solution
hi LittlePero
Thx for the fast reply, I can't see it trough BI:
but can trough VS or Tabular Editor:
Values are 0 or -1 instead of 1.
cheers
- az386 years ago
please, share your statement with CASE that defines the value. without it, it's almost impossible to help
- LittlePero6 years agoNew Member
Sure, here it is:
As said before, the function worked good, it was returning values as it should, I don't think it's the cause of the problem. Could it be some miss-match of the date formats fields in "Date" view I was changing few days before?
- az386 years ago
well, LittlePero
if you could delete sensitive data from your report and share pbix-file it would be helpful for further troubleshooting
