Aakash15's avatar
Aakash15
3 years ago
need help with resolving double '-' symbol from dymanic datalable using tabular editor
Hello
I am in need to present a bar chart with dynamic data lables (data lables drived by dax). to acheive that I have use external tool called tabular editor. with this i written format string expression.
The requirement is i need to concadiante '-' for negative values and '+' for positive values and also % for some attributes.
below i present the dax in tabular editor Ver.2
Here i used format string expression to customise the data lable
this is output. we can clearly see double '-' symbol at the first value but for others all is fine.
I need help regarding this
  • timtack's avatar
    timtack
    I found your topic Aakash15 while searching for an answer for my dynamic format problem, because i got two -- for negative values. I found an answer for my dynamic formatting with some behaviour testing.
    E.g. i wanted following format, but for negative Values i got "-- XXX K":
    """" & FORMAT(SELECTEDMEASURE(), "#,0, K")
    Then i tested where this second - came from. I recognized, that PowerBI adds an "-" infront of my Format(...). With following code, the result was "-  -XXX K"
    "  " & FORMAT(SELECTEDMEASURE(), "#,0, K")
    So i wanted to get rid of one minus. I achieved that with formatting negativ values like positive ones, because it adds an "-" before Format(). This works for me:
     """" & FORMAT(SELECTEDMEASURE(), "#,0, K;#,0, K")
    Eventhough the answer is pretty late, i hope this helps you or someone else!
    • Aakash15's avatar
      Aakash15
      Hello Amit,
      Really thanks for Reply. but unfortunatly it doesn't solve the issue. i went with bit of hardcoaded way, right now its fine but with no surity, I ll be glad if you can help with any other solution to it.
      Thankyou.
