UHS's avatar
UHS
1 year ago
Need help with relationship between two tables
Hi All,
I am having two tables between which there is no relation plus there is no unique key to identify unique records.
COls from table A to be used
Year-QuarterCost CentreOP_expense_Sub_catAmt_InQ_000s_Actual1Actual Allocation1Amt_InQ_000s_Budget1Budget Allocation1
COls from table B
FC_LOBCost CentreFunction codeAct SKF%
Final Expected result from both tables
Year-QuarterFC_LOBCost CentreFunction codeOP_expense_catOP_expense_Sub_catAmt_InQ_000s_Actual1Act SKF%Actual Allocation1Amt_InQ_000s_Budget1
Budget Allocation1
The cost centre in both the tables are not unique and for one costcentre there are multiple function codes. i want this func code col and act skf% to be in the table A
Both table have many to many relationship created and i have even added the cols from both the table in table visual. i am using related func and lokup func to add the table b col in table A but i get errorrs for multiple values are there where single value is expected.
How can i achieve this..
Appretiate quick help
  • Hi Everyone,
    Thanks so much for your replies.
    I found the solution to my problem and here is what i did.
    I created a bridge table between these two tables and added al lth eunique cost centres there and then indivisually joined tables by oneto many relationship as
    Table A many to one relation with Bridge table and Table B many to one relation with Table A and make it active and also filter direction to be selected as both.
    Then createe 2 measures in the table 2 where i wanted to have the logic updated
     Following all these steps my issue gor resolved.
  • How are you trying to add the column?  Within a measure on the visual or with a calcualted column on the table?  The error you are getting is usually a context error where the function you wrote is expecting a single value (row context) but a column of multiple values is referenced instead of a single value.
    Could you paste the code of your measure/calculated column for us to better understand what's going on?
    • UHS's avatar
      UHS
      PFB data for reference
      Table ATable BTable BTable BTable ATable ATable ATable B
      Year-QuarterLBCCFCCatSubcatAmountAct%
      2024-Q1NonCore1000000000-AA000CompensationBonus7.28499.6
      2024-Q1NonCore1000000000-AA000CompensationOther Benefits13.705499.6
      2024-Q1NonCore1000000000-AA000CompensationPension Expense5.7077699.6
      2024-Q1
      NonCore1000001111-AA1111Invest ExpInvest Exp-31.391260.4
      2024-Q1NonCore1000001111-AA1111CompensationBonus7.2840.4
      2024-Q1NonCore1000001111-AA1111CompensationOther Benefits13.70540.4
      2024-Q1NonCore1000001111-AA1111CompensationPension Expense5.707760.4
      I have highlighted the columns to identify which is coming from table A and B. Many to many relation is created between these two tables and this is what i see in my report visual right now.
      Now i want to create two logics, i.e. if the cat is Invest Exp then Act% should be 100 else as it is and Fc should be AA1010 else as it is. so expected result should be as below :
      How can i achieve it.
      Note: @ different tables.. Joined based on mamuy to many relation
      2024-Q1NonCore1000001111-AA1010Invest ExpInvest Exp-31.39126100
      0.4
      • d_m_LNK's avatar
        d_m_LNK
        Thanks for the sample data, with which columns are you relating the tables?
  • UHS
    could you pls provide some sample data and expected output?
    • UHS's avatar
      UHS
      Hello Ryan,
      thanks for your message.
      2024-Q1
      0.4
      • ryan_mayu's avatar
        ryan_mayu
        Pls provide the sample data for table A and B separately.
    • UHS's avatar
      UHS
      Thanks for yuor reply, my issue got resolved
  • Hi Everyone,
    • v-dineshya's avatar
      v-dineshya
      Hi UHS ,
      Thanks for the update and happy to know you have found a solution. Mark it 'Accept as Solution'. It may help others who may be in similar scenarios.
