Need help with Power BI Map visual for Data Labels
In Power BI's native Map visual, there is no Data Label option available, only a Category Label option available. I want to add both Data Labels and Category Labels.
Please suggest a workaround or a custom label solution to display both.
Hi nileshpatil080 - we have custom map charts but most of the charts display category labels then data values . I think it is because of the privacy and GDPR policies.
above custom charts supports only category label but not numbers.
Did I answer your question? Mark my post as a solution! This will help others on the forum!
Appreciate your Kudos!!
- rajendraongole1
Hi nileshpatil080 - It is one of the limited feature in Map visual not available in Power BI to display data label other than Data categories.
You can configure the tooltip page to show both measures. You can customize the tooltip to display the measures in a clear and organized manner.
Appreciate your Kudos!!- nileshpatil080Regular Visitor
Hi rajendraongole1 ,
Do we have any custom visuals that are Power BI certified to show Data Lables.
- rajendraongole1
