Karla_hernandez
3 years agoNew Member
Need help with Position Changes DAX formula
I have a historical table that brings in employee data each month. This means the same employee can have multiple records in the table. I am trying to write a DAX measure that looks at the employee's...
parry2k
3 years agoKarla_hernandez there are so many posts on doing the head count. did you take the time to search for it and see if existing solution will work for you?
Karla_hernandez
Yes I have been searching for a solution for over a week now. I have a seperate headcount report that calculates headcount based on an employees single record
In this case I want to account for any position changes an employee has had and only want to include in the count the employees latest record. For example, In june an employee may be in X position and they should be included in the X position headcount for June but in July that employee moved to Y position and should now be included in the Y positon for July headcount.
