Need help with parameter in SQL statement
- 6 years ago
I think these details already Greg_Deckler has provided. these are a couple of link for the same
https://docs.microsoft.com/en-us/power-query/power-query-query-parameters
https://community.powerbi.com/t5/Desktop/How-do-I-pass-parameters-to-my-SQL-statement/td-p/118716
Following is what I have;
SELECT [PointName]
,[PointID]
,[PointSliceID]
,[UTCDateTime]
,[ActualValue]
FROM [JCIHistorianDB].[dbo].[RawAnalog]
WHERE UTCDateTime > DATEADD(MONTH, -1, GETDATE())
AND PointName LIKE '%NCE26%'
This works fine (with the parameter SQL IP Address, but the NCE26 It must be replaced by a parameter. When connecting to the database the follwing screen appears. (Search is the name of the parameter)
OK, assuming you have the parameter setup correctly, can you share at least the first few lines of your Power Query M code? Used Advanced Editor in Power Query, I mainly need to see your Source line.
- Martin746 years agoHelper I
Source = Sql.Database(#"SQL IP Address", "JCIHistorianDB", [Query="SELECT [PointName]#(lf) ,[PointID]#(lf) ,[PointSliceID]#(lf) ,[UTCDateTime]#(lf) ,[ActualValue]#(lf) FROM [JCIHistorianDB].[dbo].[RawAnalog]#(lf) WHERE UTCDateTime > DATEADD(MONTH, -1, GETDATE())#(lf) AND PointName LIKE '%NCE26%'"])
SourceComplete copy of the source line
