Need help with parameter in SQL statement
- 6 years ago
I think these details already Greg_Deckler has provided. these are a couple of link for the same
https://docs.microsoft.com/en-us/power-query/power-query-query-parameters
https://community.powerbi.com/t5/Desktop/How-do-I-pass-parameters-to-my-SQL-statement/td-p/118716
So you have a Query Editor parameter setup like the screen shot below?
Following is what I have;
SELECT [PointName]
,[PointID]
,[PointSliceID]
,[UTCDateTime]
,[ActualValue]
FROM [JCIHistorianDB].[dbo].[RawAnalog]
WHERE UTCDateTime > DATEADD(MONTH, -1, GETDATE())
AND PointName LIKE '%NCE26%'
This works fine (with the parameter SQL IP Address, but the NCE26 It must be replaced by a parameter. When connecting to the database the follwing screen appears. (Search is the name of the parameter)
- Greg_Deckler6 years agoCommunity Champion
OK, assuming you have the parameter setup correctly, can you share at least the first few lines of your Power Query M code? Used Advanced Editor in Power Query, I mainly need to see your Source line.
- Martin746 years agoHelper I
Source = Sql.Database(#"SQL IP Address", "JCIHistorianDB", [Query="SELECT [PointName]#(lf) ,[PointID]#(lf) ,[PointSliceID]#(lf) ,[UTCDateTime]#(lf) ,[ActualValue]#(lf) FROM [JCIHistorianDB].[dbo].[RawAnalog]#(lf) WHERE UTCDateTime > DATEADD(MONTH, -1, GETDATE())#(lf) AND PointName LIKE '%NCE26%'"])
SourceComplete copy of the source line
- amitchandak6 years agoSuper User
Just had to change the Power Query M code. Thanks for sharing the posts, the red-gate link gives me the solution!
Right, you should have just had to change the code to:
let Source = Sql.Database(#"SQL IP Address", "JCIHistorianDB", [Query="SELECT [PointName]#(lf) ,[PointID]#(lf) ,[PointSliceID]#(lf) ,[UTCDateTime]#(lf) ,[ActualValue]#(lf) FROM [JCIHistorianDB].[dbo].[RawAnalog]#(lf) WHERE UTCDateTime > DATEADD(MONTH, -1, GETDATE())#(lf) AND PointName LIKE '%Search%'"]) in
