Need help with my code - incremental calculated column DAX
Hi everyone,
I need help fixing my code for an incremental column based on 2 conditions.
Here it is:
It is not working properly because you can see in row 16 I don't want to be shown a 3, but a 2. You see it is happening because the column is based on a calculation that gives back the difference between number of rows so I need to add one condition to my code in order to fix this. The problem is, I can't figure out how.
This is the code:
Column 3 =
VAR c = 'Tot MD_TEST'[Data]
VAR pre =
MAX ( 'Tot MD_TEST'[Data] ),
FILTER ( 'Tot MD_TEST',
'Tot MD_TEST'[Data] < c
&& 'Tot MD_TEST'[A] = 0
&& 'Tot MD_TEST'[Name] = EARLIER('Tot MD_TEST'[Name])
VAR data_prec =
CALCULATE(
MAX('Tot MD_TEST'[Data]),
FILTER(
'Tot MD_TEST','Tot MD_TEST'[Name] = EARLIER('Tot MD_TEST'[Name]) &&
'Tot MD_TEST'[Data] < EARLIER('Tot MD_TEST'[Data])
IF (
'Tot MD_TEST'[A] <> BLANK (),
IF('Tot MD_TEST'[A] = 1,
IF('Tot MD_TEST'[B] = 1,
COUNTROWS ( 'Tot MD_TEST' ),
FILTER (
'Tot MD_TEST',
'Tot MD_TEST'[Data] <= EARLIER('Tot MD_TEST'[Data])
&& 'Tot MD_TEST'[A] <> 0
- CALCULATE ( MAX ( 'Tot MD_TEST'[Column] ), FILTER ( 'Tot MD_TEST', 'Tot MD_TEST'[Data] = pre && 'Tot MD_TEST'[Name] = EARLIER('Tot MD_TEST'[Name])) ),
1),
0
Thank you!
- Anonymous3 years ago
Hi maddaelle ,
Please try this code to create a calculated column.
Column 3 = VAR _Step1 = ADDCOLUMNS ( 'Table', "Step1", SWITCH ( TRUE (), 'Table'[A] = 1 && 'Table'[B] = 0, 1, 'Table'[A] = 0 && OR ( 'Table'[B] = 0, 'Table'[B] = 1 ), 0 ) ) VAR _Step2 = ADDCOLUMNS ( _Step1, "Step2", MAXX ( FILTER ( _Step1, [Index] < EARLIER ( [Index] ) && NOT ( ISBLANK ( [Step1] ) ) ), [Index] ) ) VAR _Step3 = ADDCOLUMNS ( _Step2, "Step3", VAR _VALUE = SUMX ( FILTER ( _Step2, [Index] = EARLIER ( [Step2] ) ), [Step1] ) RETURN IF ( ISBLANK ( [Step1] ), _VALUE + [Index] - [Step2], [Step1] ) ) RETURN SUMX ( FILTER ( _Step3, [Index] = EARLIER ( 'Table'[Index] ) ), [Step3] )Result is as below.
Rico ZhouIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
- maddaelleFrequent Visitor
Hi everyone,
I am a newbie in powerbi and struggling with a quite complex task.
I need to get a measure of "chain sessions" per user that I want to use for conditional formatting later and here is how it should work.
I need to get in Powerbi these 3 columns or calculations:
- column A that measures if the session duration (per user) is >= 45 minutes
- column B that measures if the difference between this session and previous session (per user) is < 5 days.
- column C contains the logic on how I want to get my chain session measured.
I am struggling understanding how to get the same thing done into powerbi, not sure if I should choose a calculated column or a measure since all of this measure should also consider the UserID in that table, should be calculated on the previous row for that specific UserID.
This could be the whole table, please note that I added first 3 columns only to get a general understanding, it does not work with calculations I made before.
Every day I get the sessions for each UserID.Can someone help me with that?
Thank you,
- v-yalanwu-msftCommunity Support
Hi, maddaelle ;
You can refer to the following recursive functions for power query, such as @fx(x-1);
M Language Functions - PowerQuery M | Microsoft Learn
Community Support Team _ Yalan Wu
If this post helps, then please consider Accept it as the solution to help the other members find it more quickly. - maddaelleFrequent Visitor
Thank you, I appreciate your help, but I was looking for something with DAX
I posted my first post last week and worked on it, now I need some help trying to fix my code which is almost working.
I found this post previously https://community.powerbi.com/t5/Desktop/How-can-I-write-a-formula-for-incremental-addition-similar-to/m-p/931124 and applied v-diye-msft 's answer to my code.
It's a little bit different since I have to conditions to satisfy in order to get the incremental calc.
I now have column A and B which contain the conditions I need to verify (1 is true and 0 is false).
Then I need my calculation to do this:
if (A = 1, if (B = 1, incremental calc, 1), 0)
Saw in that solution I needed to create 2 columns to do so. Here they are:
As you can see, my Column 3, the one with the incremental calculation, is not working but I can't fix the error.
This is the code for Column:Column =
COUNTROWS ( 'Table' ),
FILTER (
'Table',
'Table'[Data] <= EARLIER ( 'Table'[Data] )
&& 'Table'[A] = 1 && 'Table'[B] = 1
), FILTER('Table','Table'[Name] = EARLIER('Table'[Name])))And this is the code for Column 3:Column 3 =
VAR c = 'Table'[Data]
VAR pre =
MAX ( 'Table'[Data] ),
FILTER ( 'Table', 'Table'[Data] < c && 'Table'[A] = 0 && 'Table'[B] = 0 ),
IF (
'Table'[A] = 1, if( 'Table'[B] = 1,
FILTER('Table',
'Table'[Name] = EARLIER('Table'[Name])),
FILTER (
'Table',
&& 'Table'[B] <> 0 && 'Table'[A] <> 0
- CALCULATE ( MAX ( 'Table'[Column] ), FILTER ( 'Table', 'Table'[Data] = pre && 'Table'[B] <> 0 && 'Table'[A] <> 0) ))), 1), 0)- v-jingzhangCommunity Support
Hi maddaelle
Can you show the expected column along with the current sample data? At present I don't understand why "Column 3" is not working. According to my understanding of the formula "if (A = 1, if (B = 1, incremental calc, 1), 0)", the curent "Column 3" in the image seems to have returned the correct results. Which values are not correct and what are the desired values?
Community Support Team _ Jing- maddaelleFrequent Visitor
Hi, thanks for your answer, I just updated all this work in another post, if you could check.
https://community.powerbi.com/t5/Desktop/Need-help-with-my-code-incremental-calculated-column-DAX/m-p/2934003
- amitchandakSuper User
maddaelle , can you provide logic, what are you trying to achieve
The information you have provided is not making the problem clear to me. Can you please explain with an example.
For a faster solutions refer https://www.youtube.com/watch?v=UrFuZ2uHjdY
Appreciate your Kudos.- maddaelleFrequent Visitor
Hi amitchandak, thanks for answering.
The Logic I want to implement in column 3 Is this:
First case : IF A = 1AND B = 0 THEN 1
Second case : IF A = 0 AND B = 0 or 1 THEN 0
Third case : IF A = 1 AND B = 1 COLUMN3[PREVIOUS ROW] =+ 1
In ROW 16 there Is an error since the previous ROW value Is 1 so i want It to give back 2 (1+1).
Line 14 Is correct, line 15 also because it gets the result for second condition, but line 16 should make the incrementale work.
Example
A B C3
1. 0. 1
0. 1. 0
0. 0. 0
1. 1. 1
1. 0. 1
1. 1. 2
1. 1. 3
1. 1. 4
1. 0. 1
- AnonymousNot applicable
Hi maddaelle ,
