Need help with measure
Hi PowerBI Experts!
Here's the current measure for "Remark"
If(isblank(Sum(PS_Financials[CurrentBudget])), if( Sum(PS_Financials[Actual]) > 15000,"At Risk",if( Sum(PS_Financials[Actual]) > 0," On Forecast",blank())), If( isblank([#Spend %]) ,"",If( [#Spend %] > 1,"Over Budget",If( [#Spend %] > 0.9 ,"Issue", If( [#Spend %] > 0.75, "At Risk","On Forecast")))) )
The item in red box should return "At Risk" under Remark column. May I know why is it not the case?
Basically, this is the logic that I want :-
- IF Actuals > 90% of the budget and Actual < Current Budget, then "Issue" (flagged as Purple)
- IF Actuals > Current Budget, then "Over Budget" (flagged as Red)
- IF Actuals < 90% of the budget and > 75% of the budget, then "At Risk" (flagged as Orange)
- IF Actuals < 75% of the budget, then "On Forecast" (flagged as Green)
- IF Budget = 0 and Actuals > 15,000 ($20,000 x 75%), then "At Risk" (flagged as Orange)
- IF Budget = 0 and Actuals < 15,000 ($20,000 x 75%), then "On Forecast" (flagged as Green)
Thank you!
Hi hushpuppies
Your first condition says that SUM ( PS_Financials[CurrentBudget] ) must be blank before proceeding to the next. However, the row in question is showing zero. Try changing ISBLANK ( SUM ( PS_Financials[CurrentBudget] ) ) to ISBLANK ( SUM ( PS_Financials[CurrentBudget] ) ) || SUM ( PS_Financials[CurrentBudget] ) = 0
- danextian
Hi hushpuppies
- hushpuppiesFrequent Visitor
Thanks danextian - it worked!
