InsightSeeker's avatar
InsightSeeker
2 years ago
Need help with Measure
I have a yearly value in my database, which i need to show it on monthly basis.
I have created a measure as  Contracted  = SUM(Contracted_Volume_Yearly])/12  to get the result for each month.
Now when i displaying this measure in Matrix visual, the column "grand total" does not show the correct total amount. How can i have this fixed?
         1,000,000
  • Daniel29195's avatar
    Daniel29195
    InsightSeeker
    if we assume that you are using month in the matrix  :
    use the following pattern :
    sumx ( values ( tbl_name[month_col_name] ) ,  SUM(Contracted_Volume_Yearly])/12  )
    let me know if this helps /
    If my answer helped sort things out for you, i would appreciate a thumbs up 👍 and mark it as the solution ✅
    It makes a difference and might help someone else too. Thanks for spreading the good vibes! 🤠:
