Amaan's avatar
Amaan
4 years ago
Need Help with MEASURE
I have a few columns of a product table that I need to put in a measure. The columns are revenue, profit and margin.
What I need is a measure that can help me assign certain weightage to each of these columns.
For eg, - I need weightages of Revenue to be 40%, Profit be 25% and Margin be 35%.
This way for every product that I select from the product name slicer, the measure gives me a number that is calculated from these 40,30,30 percentages.
So if product 1 is selected, and it has revenue as 100, profit as 10 and margin as 30, so it should convert them into respective weightages and give me a final number.
I hope I am clear enough in my query. Pardon me for my unclear language if any, as I am only a 1-month user of power BI.
  • Hi Amaan ,
    You can try this method:
    I assume the percentage is 40%,25%,35%.
    Here is my sample data:
    New measure:
    FinalNumber = SELECTEDVALUE('Table'[revenue]) * 0.4 + SELECTEDVALUE('Table'[profit]) * 0.25 + SELECTEDVALUE('Table'[margin]) * 0.35
    The result is :
    Is this what you expect?
    Hope this helps you.
    Here is my PBIX file.
    Community Support Team _Yinliw
  • v-yinliw-msft's avatar
    v-yinliw-msft
    Hi Amaan ,
    New measure:
    The result is :
