Anonymous's avatar
4 years ago
Need help with Measure
Hello All,
Hope you are doing well 🙂
I have a measure as mentioned below in pbix which is used to sum of sales for last 7 days . but unfortunately i was not able to see any result in visual . please let me knw what went wrong.
Test Measure =
var a= MAXX(DateTable,DateTable[Future 8 fridays])
var b=a-6
var c=CALCULATE(SUM('Combined Data'[Funding]),'Combined Data'[Approval Date - Forecast]>=b && 'Combined Data'[Approval Date - Forecast]<=a)
return c
  • dhruvinushah's avatar
    dhruvinushah
    Icon for Responsive Resident rankResponsive Resident
    Hi Anonymous ,
    Your measure is working for the MAX date or the last date in the Future 8 Fridays field.
  • Hi,
    Share the download link of your PBI file and show the expected result.
    Try this
    var a= selectedvalue(DateTable,DateTable[Future 8 fridays])
  • v-xiaotang's avatar
    v-xiaotang
    Hi  Anonymous
    Thanks for reaching out to us. I need to confirm the questions in the picture below,
    Community Support Team _Tang
    If this post helps, please consider Accept it as the solution to help the other members find it more quickly.
      dhruvinushah
      Hi v-xiaotang  , Yes i think so. They are trying to create a table visual to show the Week to date sum of the [Funding] field. And just show those WTD values for those Future 8 Fridays fiels as shown in the screenshot above.
        v-xiaotang
        Hi dhruvinushah
        Thanks!
        In this scenario, create the measures below,
        Test Measure =
        var a= MAXX(all(DateTable),DateTable[Future 8 fridays])
        var b=a-6
        return c
        result ( in card visual)
        If you want to put it into table visual, then use this measure
        Measure =
        var _maxdate= MAXX(all(DateTable),DateTable[Future 8 fridays])
        var _start =_maxdate-6
        var _sum=CALCULATE(SUM('Combined Data'[Funding]),'Combined Data'[Approval Date - Forecast]>=_start && 'Combined Data'[Approval Date - Forecast]<=_maxdate)
        return IF(MIN(DateTable[Future 8 fridays])= _maxdate, _sum)
        result
