Bokazoit's avatar
Bokazoit
Icon for Post Prodigy rankPost Prodigy
4 years ago
Need help with measure
This measure is created using a detached Date dimension - as can be seen from this data model:
Doing that makes it possible to calculate the correct distinct count, using this DAX:
Antal verserende sager =
VAR MinDato = MIN('FilterDato (Verserende sager)'[DatoFilterKey])
CALCULATE(
    DISTINCTCOUNT(FactArvesager[ArvesagsKey]),
    FactArvesager[Forventet afsluttet Dato] >= MinDato &&
    FactArvesager[Bostarts Dato] < MinDato &&
    (FactArvesager[Realiseretarv Dato] = BLANK() || FactArvesager[Realiseretarv Dato] >= MinDato),
    USERELATIONSHIP(FactArvesager[Forventet afsluttet Dato],DimDato[DatoKey])
The VAR MinDato gives the  minimum date in my date filter:
But the datamodel is not that userfriendly, and I would like to use the date from my Date dimension (DimDato) instead of the detached date dimension.
The problem is that when I use the Date dimension it gives me the wrong result. If I use this measure:
Antal verserende sager test =
VAR MinDato = MIN(DimDato[DatoKey])
CALCULATE(
Were I use the Date Dimension (DimDato) instead of the detached date dimension, I get 4 records more:
The minimum date is 1. april 2022:
The green row is correct since it is before the minimum date and the filter in the measure works, but the 4 red rows is not correct as can be seen - since all 4 records is after 1. april 2022.
To me it looks as if the variable MinDato (= minimum date from the datefilter) is calcualted differently than I would expect.
So therefor I need to have a detached date dimension. Can You tell me how to get the date correct?
Any help is really appreciated 🙂
  • It's not clear what the actual issue is.  Why would a disconnected data table that feeds your slicer be "not user friendly" ?
    • Bokazoit's avatar
      Bokazoit
      Because the user have to use one dimension for filtering, and another for date types
  • I think You should post this in Your own thread 🙂
    Hi Bokazoit ,
    How about modifying this measure?
    VAR MinDato = MINX(ALL(DimDato),DimDato[DatoKey])
    CALCULATE(
    If it does not help, how about creating relationships like the Filterdato?
    If I have misundstood your meaning, please provide your desired output and your  pbix file without privacy information.
    Community Support Team _ Polly
        Hi Bokazoit ,
