gauravnarchal's avatar
gauravnarchal
Icon for Post Prodigy rankPost Prodigy
5 years ago
Need help with Measure
Dear All - I need your help to create a measure as below
If Code is = “AAEA” or “CAPJ” or “MRAJ-1” or “12786” then return PASS else FAIL
DATA
CODE
AAEA
CALJ
CAPJ
AU31
AU04
GROJ
MORJ
MRAJ
MRAJ-1
12786
MRAJ-2
87979
  • gauravnarchal
    Pls try this
    Column = if('Table'[CODE] in {"AAEA","CAPJ","MRAJ-1" , "12786" },"PASS","FAIL")
    Measure = if(max('Table'[CODE]) in {"AAEA","CAPJ","MRAJ-1" , "12786" },"PASS","FAIL")
    • gauravnarchal's avatar
      gauravnarchal
      Hi ryan_mayu  - With the measure you suggested, it is taking a lot of time to load.  Also, I am getting the below error.
      I did not try the column as I am keener to achieve this through the measure.
