ignas's avatar
ignas
Icon for Advocate II rankAdvocate II
7 years ago
Need help with filtering
Hey there,
It is a simple example of what I need to achieve:
If I select the answer "ddddd" then  the table should show all the answers from the "recipientID" answers, not only the answer that was selected in the filter.
I cannot filter by RecipientID in the filter in the real world situation.
Does anybody know how I can do this using magic of dax?
Here is the file:
PowerBI_report_Example
  • Hi ignas ,
    Follow the steps below:
    • Create a table for the answers slicer:
      • Answers = DISTINCT(Survey[Answer])
    • Create the following measure:
    Filter answer =
    VAR USERID =
        LOOKUPVALUE ( Survey[RecipientID]; Survey[Answer]; VALUES ( Answers[Answer] ) )
        IF (
            DISTINCTCOUNT ( Answers[Answer] )
                = CALCULATE ( DISTINCTCOUNT ( Answers[Answer] ); ALL ( Answers ) );
            1;
            IF ( VALUES ( Survey[RecipientID] ) = USERID; 1; BLANK () )
    • Place this measure on the table visual filters and set it to is not blank.
    Be aware that if the answer is given by more than 1 person this will return an error. If you select all the answers it will return the full table.
    Check result attach (file is saved on June version)
    MFelix
    • ignas's avatar
      ignas
      Hey MFelix
      Very nice try, but unfortunately it could not work in any way, because in my real dataset I have over 10mln entries and some of them are repeating. Any other solution with Dax that could work?
      I have a solution where I create a separate table from all of these answers and it works just fine, but it consumes space for storing a copy of data in a separate table.
      Thanks for helping.
      Cheers
      Ignas
      • MFelix's avatar
        MFelix
        Hi ignas ,
        Not aware that you had such a big database, it was not clear on your message.
        In my example it is also creating an additional table on the model, because looking at interactions between the visuals if they are from the same table they will filter out the information so you are being a victim of the setup of the data.
        If you have a single table and you have a slicer and a chart when you apply filter on the slicer the corresponding visual will have the same filter you cannot dissociate one from the other since they are within the same table.
        MFelix
