Need help with DAX code for cumulative values
- Anonymous1 year ago
Hi honeybee84 ,
Thank you for reaching out to Microsoft Fabric Community Forum.
johnt75 bhanu_gautam Thank you for your quick inputs.
honeybee84 Could you please try the below DAX measure.:
Cumulative Prior Month Forecast =
VAR SelectedReportingPeriod = MAX(DIM_Date[Reporting Period])
VAR PriorReportingPeriod =
CALCULATE(
MAX(DIM_Date[Reporting Period]),
DATEADD(DIM_Date[Reporting Period], -1, MONTH)
CALCULATE(
[Forecast],
FILTER(
ALL(DIM_Date),
DIM_Date[Month] <= MAX(DIM_Date[Month])
TREATAS({PriorReportingPeriod}, FACT_CombinedData[Reporting Period]),
USERELATIONSHIP(DIM_Date[Month], FACT_CombinedData[Month])
)If this post helps, then please consider Accepting as solution to help the other members find it more quickly, don't forget to give a "Kudos" – I’d truly appreciate it!
B Manikanteswara Reddy
Hi honeybee84 ,
We wanted to kindly follow up to check if the solution provided for the issue worked? or Let us know if you need any further assistance?
If our response addressed, please mark it as Accept as solution and click Yes if you found it helpful.
Please don't forget to give a "Kudos " – I’d truly appreciate it! |
Hi honeybee84 ,
As we haven’t heard back from you, we wanted to kindly follow up to check if the solution provided for the issue worked? or Let us know if you need any further assistance?
- Anonymous1 year agoNot applicable
Hi honeybee84 ,
May I ask if you have gotten this issue resolved?
If it is solved, please mark the helpful reply or share your solution and accept it as solution, it will be helpful for other members of the community who have similar problems as yours to solve it faster.
