Anonymous's avatar
4 years ago
Need help with calculating common data using Dax
Hi ,   I am new to Power bi. There is a requirement to calculate the average of amount for the common part numbers. I am not sure how to achieve it using dax query.   Table1:  Country Code ...
  • johnt75's avatar
    4 years ago
    Make sure that there is no relationship between Table1 and Table2, then create the below measure
    Avg Amount =
    var benchmark = SELECTEDVALUE(Table1[Country Code])
    return IF( NOT ISBLANK( benchmark),
        var benchmarkParts = CALCULATETABLE( VALUES(Table2[Part Number]), REMOVEFILTERS(Table2[Country Code]), Table2[Country Code] = benchmark)
        var currentCountryParts = VALUES(Table2[Part Number])
        return CALCULATE( AVERAGE(Table2[Amount]), INTERSECT( benchmarkParts, currentCountryParts ) )
    Add that to a table visual with the country code column from Table2
