Need help in calculating standard deviation using custom column
- 8 years ago
Hi Anonymous,
Please try below Power Query.
let Source = Excel.Workbook(File.Contents("C:\Users\xxxx\Desktop\Sample Data (Autosaved) (Autosaved).xlsx"), null, true), data_Sheet = Source{[Item="data",Kind="Sheet"]}[Data], #"Promoted Headers" = Table.PromoteHeaders(data_Sheet, [PromoteAllScalars=true]), #"Changed Type" = Table.TransformColumnTypes(#"Promoted Headers",{{"Site", type text}, {"Code", type text}, {"DAY_DATE", type datetime}, {"DAYS", Int64.Type}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"Site", "Code"}, {{"standard deviation", each List.StandardDeviation([DAYS]), type number}}) in #"Grouped Rows"Best regards,
Yuliana Gu
Hey,
using the DAX function STDEV.S by creating a measure like so:
Measure =
CALCULATE(
STDEV.S('Table2'[DAYS])
)creates this output:
Here you will find guidance how to create a measure:
https://docs.microsoft.com/en-us/power-bi/desktop-tutorial-create-measures
And here is something about the DAX function STDEV.S
https://msdn.microsoft.com/en-us/query-bi/dax/stdev-s-function-dax
Hopefully this gets you started
Regards
Tom
- Anonymous8 years agoNot applicable
Thanks Tom & Stachu for your reply, I want same kind of logic to be done under query editor --> Custom Column because I need that result in a new column so that i can build rest of logic on top of it.
Stachu - It's actual standard devation data source & Expected output which is implemented in diff tool which we are migrating in power bi.
- Stachu8 years ago
so you want to group the table with a new column calculating stadard deviation?
one more question - is the output you showed based on exacly same dataset that you posted? When I calculate the standard deviation I get the same results as the ones that TomMartens has posted, which are not consistent with your outcome (see YP site)- Anonymous8 years agoNot applicable
Yes I want to group the table with a new column for calcuating standard deviation.
Dear Stachu / Tom please help me.
