Need help implementing WHERE clause in Power Query
In my SELECT statement, I am having trouble implementing the WHERE clause since it is using the LOWER command. I'm also struggling to get the ('(Invalid)', ('Not Specified')') parts of the statement.
SELECT DISTINCT
T_TESTCASE.ORIGIN_ID AS "Test Case ID",
T_TESTCASE.NAME AS "Test Case Name",
T_TESTCASE.TESTCASEFOLDER_NAME1 AS "Test Case Top folder name",
T_TESTCASE.FULLPATH AS "Test Case Fullpath",
T_TESTEXECSTATUS.NAME AS "Test Execution Status",
T_USER.FULLNAME AS "Test Case Designer",
T_HASREQUIREMENT.NAME AS "Has Requirement",
T_PROJECT.DOMAIN_NAME AS "Domain Name",
T_PROJECT.NAME AS "Project Name"
FROM T_TESTCASE
INNER JOIN T_TESTEXECSTATUS ON T_TESTCASE.T_TESTEXECSTATUS_ID = T_TESTEXECSTATUS.T_TESTEXECSTATUS_ID
INNER JOIN T_USER ON T_TESTCASE.T_DESIGNER_ID = T_USER.T_USER_ID
INNER JOIN T_HASREQUIREMENT ON T_tESTCASE.T_HASREQUIREMENT_ID = T_HASREQUIREMENT.T_HASREQUIREMENT_ID
INNER JOIN T_PROJECT ON T_TESTCASE.T_PROJECT_ID = T_PROJECT.T_PROJECT_ID
WHERE
NOT (T_TESTCASE.TESTCASEFOLDER_NAME1 IN ('(Invalid)', '(Not Specified)')
OR LOWER(T_TESTCASE.TESTCASEFOLDER_NAME1) LIKE '%archive%'
OR LOWER(T_TESTCASE.TESTCASEFOLDER_NAME1) LIKE '%recycle%bin%'
OR LOWER(T_TESTCASE.TESTCASEFOLDER_NAME1) LIKE '%temp%'
OR LOWER(T_TESTCASE.TESTCASEFOLDER_NAME1) LIKE '%delete%')
AND T_TESTCASE.DELETED_DATETIME IS NULL
AND T_PROJECT.DELETED_DATETIME IS NULL
AND T_PROJECT.DOMAIN_NAME NOT IN ('(Invalid)', '(Not Specified)')
Any advice would be amazing. Thanks.
Jsonify , Tables should be joined
you need to have two filter clauses
filter(T_TESTCASE,
NOT (T_TESTCASE[TESTCASEFOLDER_NAME1] IN ('(Invalid)', '(Not Specified)')
|| SEARCH("archive",T_TESTCASE.TESTCASEFOLDER_NAME1,1,0) >0
|| SEARCH("recycle%bin",T_TESTCASE.TESTCASEFOLDER_NAME1,1,0) >0
|| SEARCH("temp"T_TESTCASE.TESTCASEFOLDER_NAME1,1,0) >0https://www.sqlbi.com/articles/the-importance-of-star-schemas-in-power-bi/
https://www.sqlshack.com/implementing-star-schemas-in-power-bi-desktop/
|| SEARCH("delete"T_TESTCASE.TESTCASEFOLDER_NAME1,1,0) >0
&& isblank(T_TESTCASE[DELETED_DATETIME]))
, filter(T_PROJECT, isblank(T_PROJECT[DELETED_DATETIME]) && NOT(T_PROJECT.DOMAIN_NAME IN {"(Invalid)", "(Not Specified)"}))
- lbendlin
"Lower" is the least of your problems. Power Query does not have the concept of wildcards.
Lower: https://docs.microsoft.com/en-us/powerquery-m/text-lower
search: https://docs.microsoft.com/en-us/powerquery-m/text-contains
NOT IN statement: use lists: {"(Invalid)", "(Not Specified)"}
Fun fact - you can't use the lists for the search. Need to use or and and.
- amitchandak
filter(T_TESTCASE,
