xiumi_hou
Post Partisan
7 years agoNeed Help: How to remove visual level filter
Hello: I found a "can not remove" filter(highlighted in yellow). Do you know how to romove this? Since my graph can only show march data..Thanks!
parry2k
7 years agoxiumi_hou you can only remove visual lever filters you manually added, otherwise whatever columns/measures you have on visual, it will show in filter. You can surely change the value of the filter
xiumi_hou
Post Partisan
7 years agoHi Parry,
The the value is just a count measure. It seems something wrong that all this page has been filter to march. When I check my other page filter, it showed march, after I cleared it, this page still have mandatory march date selection .Any idea about this? Thanks. parry2k
